I don't build systems. I tinker with faulty existing systems. What is bothering me is the discrepancy between the specifications provided by Boxnotes and online calculators and those delivered by systems manufacturers.
e.g.
I have a 4 litre cabinet measuring 255 x 215 x 215. The port is 35mm in diameter and 120mm in length. According to Boxnotes the port is tuned to 70Hz. To get to anything approaching 'reasonable' the port would have to be three times its current length.
I have another 6 litre cabinet - it has exactly the same port tube. Are manufacturers viewing the port as cosmetic accessory?
e.g.
Not 100% sure this part makes sense - those dimensions multiply up to nearly 12 litres.
Even if they are external and the box is made of 25mm stock it's still nearly 8 litres internal. How big a driver, bracing and port have you got in there to occupy nearly 50% of the internal space?
i tried "googling" Boxnotes and seem to to be finding note taking applications for word processors...
any link to the program your using would be appreciated.
Depending on the driver, fb=70Hz sounds reasonable for a 4 litre speaker.
A lot of commercial speakers tune higher to give it a hump in the roll off which gives an impression of more bass. I looked at a non working Onkyo so called subwoofer (found a stuffed woofer) and was tuned at over 50Hz. This is quite common.
