How do you combine 4 amplifier channels into one powerful
channel ?
http://www.arkada.com/items/gravity8g1000.pdf
http://ampguts.realmofexcursion.com/Xetec_Gravity_8G-1000/
channel ?
Technical data
RMS Output power in single mode @ 4 Ohms: 8 x 83 Watts
RMS Output power in single mode @ 2 Ohms: 8 x 130 Watts
RMS Output power in bridge mode @ 4 Ohms: 4 x 260 Watts
RMS Output power in parabridge mode @4 Ohms: 2 x 330 Watts
RMS Output power in parabridge mode @2 Ohms: 2 x 520 Watts
Peak output power: >1500 Watts total
Max input Current (@13,8 V): 100 A
Idle current (no signal): 1,2 A
Fuse: 2x40 A
Total Harmonic Distortion (THD): <0,05 %
SNR: >89 dB(A)
Freq.Response (bypass mode): 7 Hz-50.000 Hz
Stability (single/bridge/parabridge): 2 /4 /2 Ohms
Input Sensitivity: 250 mV-6 V
Warranty: 1 Year
Parabridge mode:
Due to the spezial crossconection of those 4 Amp sections in 1 Channel mode the combined solution is again 2 Ohm stable.
