I posted this on AA but I don't count much on responses .It's a little bit unusual .
I wonder if adding an exponential flare from 8" throat(default Azura) to 4" would lower horn cut of frequency or at least help to load driver to 200 Hz.(I mean if I put 150hz (or 100 Hz) into exponential calculator with Azuras 80cm (32") mouth and just use calculated profile up to 8"(170mm) extending horn for about 30cm (12") What kind of results can I expect ?? I aim at 150Hz (200Hz)- 800Hz (1000Hz) bandpass.
I consider B&C 8PE21 pro driver for the task.
Azura 204Hz specs:
Mouth diameter-800mm (~32")
throat -170mm (8")
length -310mm (12,4")
T -0,8
Thanks L
Azura 204Hz specs:
throat -170mm (8")
T -0,8
Thanks L
