Coil Winder V2.0
Hi guys !
Maybe someone will be interested in my version of the machine. The machine is 10 years old. I recently modernized it, replaced the motors, rewrote the code, added functionality. However, I made descriptions in two languages, made a video with some comments and put everything in free access. The source code is open source, you can modify it to suit yourself. Links to the materials below.
If this is not the right place for my post, please move it to the right place. Thank you all !
https://ws-amp.eu/coil_winder_ru/ru.htm
https://ws-amp.eu/coil_winder_en/en.htm
Indeed most professional - I cheaped out with a cheap chinese hand-cranked coil winder with turns counter, which is OK for occasional use, and has an intuitive (i.e. simple) user interface. However when/if I had the time this is the sort of machine I'd love to design and build.
