A bit over $50 CAD. I’ll se eif i can find some closer, but that sounds reasonable. Cheap to learn something new.
dave
dave
I can get LTS50 from Solen in Montreal. With Canada Post and taxes you are about the same. And they ar out-of-stock
So you ar emy first choice :^)
A lot pricier than ModPodge 50g vrs nearly 500 ml. Denser than water so over a half kg. So over 10x costlier. But few will go thru a whole bottle let alone teh hundreds of drivers a bottle of modPodge will.
dave
dave
https://www.audiophonics.fr/en/vent...for-loudspeaker-paper-cones-50ml-p-15257.html
maybe it is cheaper you order direct from them try to make an order to see what price it will be
i will order from them but must wait to i now what cap value i shall use,, are making new speaker
They have some, and the shipping is way less. Should be on the way shortly. Thanx for shopping for me :^)
dave
dave
great i can only think it is cheaper than send it from denmark
how many Gram extra weight do you normal give to a 8 inch driver ?
- Full Range
- Coating LTS 50 with two Fostex Drivers: FF125WK and FE103SOL
