Cmoy help please!
Hey guys, i just finished putting together a basic tangentsoft cmoy and theres no sound coming out.
Led is on. I double checked my connections and everything seems right. Im using an opa2227.
What could be the problem? Any help would be greatly appreciated!
radioshack still sells em...
Really? wow...
Could it be i didnt use all 5 leads on the 3.5mm jacks? They have 2 leads for neg and 2 leads for ground, i assumed i only needed to use 1 of each...
That could be your problem; you might have the jacks wired incorrectly. I think that type of jack has pins that can be used as a NC switch. When you insert a plug it opens the switch. I can't tell from the pics how it should or shouldn't be wired.
Well, that was indeed the problem. I hooked up the wires to the right pins and amp works perfectly now. I gotta say im a little disappointed, it makes my headphones louder but theres not much difference in sound quality...
isn't that's what good headphone amp should do, just amplify and buffer the signal for headphones? if it would sound worse, it would be a bummer, if it sounds better it would be a miracle...but if it sounds the same, it's kind off ok, isn't it
Im using it with my modded fostex t50rps. I know amps dont do anything to sound quality itself, i misspoke, meant i heard amps are supposed to bring out bass and it feels like there is no real difference in bass.
try swapping opamps...cmoy is designed around two single opamps OPA134
but if you have one socket there, you have to use dual OPA2134
A Pocket Headphone Amplifier | HeadWize
Might want to add some 100nF decoupling caps from each rail to ground near the op-amp if you want to try other types. The OPA2134 might be ok without them, but it definitely wouldn't hurt. I prefer X7R ceramic type, but a film is better than nothing if that's all you have.
