CM Labs 911 Amplifier: Any owners?
Or people who've worked on the 911? I'm trying to find out what the correct bias setting should be. Apparently, there were some circuit tweaks over the years this was made, and the version on my bench most closely matches the attached schematic, courtesy of dangus.
Interesting. At first I had thought those emitter resistors were 0.6 ohms, but now that I look at them again, I can see that you're right, they're 6 ohms.
Which emitter resistor(s) should I measure across for the bias?
Now that I look more closely at the schematic, the bias is actually specified. 50 mV at the emitter of Q11. That’s higher than I thought it would be considering that the bias stack is just an adjustable resistor. They are hoping that 3 ohms of effective emitter resistance (an ohm and a half for the whole stage) is enough to prevent runaway. It might be. That’s a lot of emitter resistance.
Reactions: dbxdx5
