Clock upgrade cdpro2
I`m looking for a way to upgrade the clock which comes standaard with the cd-pro2. As I checked out the pcb, I did not see a crystal anywhere! Does anyone know where it is lockated? Or have a scheme of the board, with the crystal on it?
I sure hope it is possible to upgrade...
I figured that it would be a higher setting, as philips usualy uses high frequencies in their design. Guess not in this module. I will look it up, when I have gathered al the info, -how to reclock- I will post it. Might save others time to figure it out.
