coloradosound said:Nice to see the clock expert find this thread!
Hey Guido checked your site and wondering if you know
freq. for Denon DVD-2910 as listing is just for CD transports/
players. Also have a Theta Data II that I'm not sure if it's worth
doing new clock or if it is more critical in outboard DAC?
Hi
very likely 27.000 MHz as it is a DVD player
External DACs bennefit from SPDIF reclocking as done in my XO3.2 clock board
Prior to upgrading the DAC clock, one should always first upgrade the drive clock
best
Guido Tent said:
Hi
best
Dear Guido, will you supply 22.5792MHz XO can??
Hi
I have not, but 44.1584 + divide by 2 will do
best
Guido Tent said:
Hi
best
I see.... thank you....
Guido Tent said:
Hi
best
Dear Guido:
If I have limited space in the DAC, how can improve Power Supply to the TCXO? any suggestion to me?
Currently using Separate Block 6V AC Transformer -> full wave rectification by IRF 11DQ10 -> 100uF/16 Cap -> LM1117-3.3 -> OS-CON SP 560uF/4V -> Murata Ferrite Bead -> TCXO, 0.1uF film cap between Vcc and Gnd under the TCXO Can.
Hercules said:
Dear Guido:
Try this:
http://www.diyhifi.org/forums/viewtopic.php?f=36&t=1570&start=0
Scroll down to lennypl's post
QSerraTico_Tico said:
Try this:
Good suggestion ! 30 dB more quiet than any LM117 .....
best
- Digital Line Level
- Clock Jitter Cleaners
