Clock generator for 192KHz USB DAC
I am searching for 192Fs or 128Fs MCLK clock generators for the 192KHz I2S DAC and came across MAX9485 from Maxim and PLL170x from TI. The datasheets of these two parts say that they can generate 256Fs or 384Fs for 96KHz sampling rate and do not say anything about support for 192KHz. Can I configure these clock generators for 96KHz @ 256Fs or 96KHz @ 384Fs and use the ouptput as 128Fs or 192Fs for 192KHz sampling arte respectively as the master clock requirement is same.
96KHz @ 256Fs = 192KHz @ 128Fs
96KHz @ 384Fs = 192KHz @ 192Fs
Thanks in advance
regards
Mahen
