Hi all,
how polarised jfet for have a perfect clipping? i want to built a line stage preamp single ended with gain of 10-12 db but when i have my perfect gain i have a problem with my clipping, positive peak clip but not negative. Why? Somebody can help me! thank you! Maxpou
what is the voltage on the output?
How far can the output voltage swing until either rail starts to limit?
Can you move the quiescent bias voltage on the output to equalise the available swings to either supply rail?
The reason is that the constant current source needs a finite voltage across it to work properly.
