Generally speaking, if you can turn the clicky knob forever without end, then it is an encoder. If it only turns up to a certain point and stops, then it could be multi-position switch (step attenuator) or simply a pot with detents.
Encoders are easy enough to find on Digikey. I ordered a couple for my amp build, $1.52 a piece IIRC.
