Cleaning Nople pot...
I have a "scratchy" Noble conductive plastic "four leg" stereo pot in an old Nikko pre. Is it possible to disassemble and clean these without watch springs, levers, ball bearings and gears flying across the room?
The direct replacement is $65.00 at partsconnexion, so an hour spent is time well spent.
There are no openings...
This pot looks like this...
access is effected by the two screws on the shaft end.
But what fun lies beneath?
I could be wrong but I don't think opening up your pot is 'lifting the lid to Pandoras box'. Might want to give it a try, slowly, still better than a new $65.00 pot???
Or, maybe drill two small clean holes where the two carbon strips are to get you little 'straw' nozzle in there??
edit: - This is cool, I did a quick 'WIKI' and found this link:
http://www.geofex.com/Article_Folders/potsecrets/potscret.htm
The Secret Life of Pots, the cleaning and repairing of potentiometers...
those pots are similar to a lot of pots i've seen before. remove the screws and invert (shaft down)hold the shaft in a pc board vise, take off the end bell, and lift up the other parts just enough to get at the etched side of the wafers with the cleaner solution. flush the wafers and reassemble. IIRC the etched side of the wafer is the back side on these pots, but i've seen them assembled both ways. it's possible that one of the rotors is pinned in place, so you may have to remove the retaining clip on the shaft to get enough give in the action to separate the halves.
