Just completed my first ever build, PC's Classix II. Great project and they sound good, but the tweeters seems a little muted. I realize they are not supposed to be overly bright, but ....
Are there any common mistakes that I should look for first?
Thank you for any suggestions.
CR23
CR23
Cheap tweeters usually do vary in sensitivity and top end frequency response a little bit more than expensive ones. Tweeter level also is a matter of taste and room acoustics. However, provided you wired the crossover correctly, you still can exchange the two resistors in the tweeter section (4 Ohm in series and 6 Ohm in parallel). That will rise the tweeter level by 2.5 dB and should make a difference.
