CLASS H power amplifier
I am building a class H power amp using 3 step supply transformer,
So highest supply is 160 volts DC ..
While i am giving maximum signal i am getting only 63volts rms dc @2ohm...
Where the all supply went?
On other hand i build an class AB amp i used an 130volts DC supply transformer.. and got 77 volts RMS output @2ohm.... isn't AB better than in output?
Kindly help ke out..what might be the wrong here ?
