Class D Output Cores
According to my practical tests about inductor cores at 200khz switching of which is my best preference for class d amplifier, i noticed too much noise at (music pause) using a phone as audio source charger plugged in then thru a mixer to my class d prototype using sg3525 as signal generator & ir2110 & buffers as fets drivers. There's too much noise using t130-2 core carbonyl than when i changed to a blue aph33p60. Infact this blue core is absolutely quiet. Some things are better done practically than reading theories to actualize outcomes.
Using Aph33p60 Core quit hard to find
Welcome on the forum, straight to action in fifth gear.
You may want to use good electrolytic caps instead of Decon THS series. Like Panasonic FR.
Wire connections to PCBs are best made with PCB connector blocks like Phoenix MKDSN.
