Class D newbie attempting project
Hi everyone,
I'm interested in making a class D power amplifier, I've searched for information in many websites, but I've only found block diagrams, I don't know which components I should use, I'm not interested in class d chipamps, I want to make a discrete design, but at IC level not at transistor level, I also want to know which are the best output mosfet models to use, it's better to use negative feedback or not.
I also don't know how to implement the switching controller, because if I have shoot thru I can destroy the output devices.
Thank you very much for your atention,
Best regards,
Daniel Almeida
I have used the circuit from the application notes.
I had a few problems.
The 2092 is fussy about decoupling.
PCB layout needs to be short and fat.
The basic circuit causes the 2092 to reset itself on high power output, so I used potential dividers on the inputs for measuring mosfet DS.
I didn't use any protection except for fuses.
I found for getting 1000watts I needed mosfet gate drivers IC's (TC4420) for driving 4 off irfb4227.
