Class D IC as modulator
Hi 🙂
I have build several Class-D amps in the past, with chips from TI, but also semi discrete. But always Full-Bridge designs with clock. (not self oscillating) I just wondered if anybody already tried an amp with a low power class D ic as modulator. Like a PAM8406 or MT6905.
Greetings
David
Umm... No they're actually not 🙂 Not if by "they" you mean those two low-power class-D amp chips.
If you check the datasheets for those, you'll notice they also contain the MOSFET outputs ("already") 😉
http://www.maxictech.com/uploads/soft/201302/1_01160014.pdf
The giveaway here are the Rdson numbers on page 15. Rdson = on-state drain-to-source resistance, which is a characteristic of the output MOSFETs (looks like there are both P-channel and N-channel ones). The block diagram isn't too revealing, with the "modulation" black-box encompassing the output stage as well.
https://www.mouser.com/ds/2/115/PAM8406-247303.pdf
This other one's a little bit more detailed.
Hi BBC,
A very good idea and it really works.
It simplifies the headache of making a discrete modulator, triangle generator, preamp etc etc.
I have tried it with MAX4295 clocking at 250Khz with universal feedback and it works better than any discrete design. Simple BOM and compact.
Beast of luck for trials.
Ajazz
Hi BBC,
Ajazz
Hi Ajazz,
Can you post some scheme of the feedback implementation at this case? How the "modulator IC" already have a internal loop feedback to drive directly a speaker , did you put the feedback directly to the diferential input of IC? Don't have issues with the clock stability making this?
