I have Mission Audio BX1 speakers.
Specs:
70W RMS
88db sensitivity 1W@1m
8 ohms
amp recommendation 15-70W
5.5" bass driver/1" tweeter
Now I have long driven these with a Lepy LP-2020A amp, and I am happy with the sound, providing I use my Soundblaster soundcard, not the built-in motherboard sound, which is terrible.
Anyway, now I have taken my speakers to Indonesia, but left the amp behind. Market for Hifi is poor, second-hand equipment is hard to find, or designed for loud volume, not listening pleasure.
I can order very easily from AliExpress (or similar). We have a $75 + shipping customs limit, so anything under that price would be ok.
I would like to be able to achieve max volume on occasion, because sometimes there is other loud music nearby.... So I think I need something that will make out my speakers.
And of course the bluetooth as before I had it connected to a desktop PC, but now it is going to be a laptop or phone, so an rca cable would not be a good choice for me.
Specs:
70W RMS
8 ohms
I would take a look at the large variety of TPA3116 and TPA3118 based board available on the internet. You can even get them as a plate amp for around 30 dollars so you can turn your bookshelf speakers into active speakers.
How about this?
TPA3116 + NE5532
AIYIMA 2.0 Bluetooth 4.2 TPA3116 HIFI Dual Core Fever Digital Power Amplifiers Audio Board Amplificador 100Wx2 For Home Theater-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
or this?
TPA3116 + TL072c
Aliexpress.com : Buy AIYIMA Bluetooth 5.0 TPA3116 Digital Audio Amplifier 100W*2 HiFi Stereo Class D Power Amplifier AMP With PCM5102 DAC Decoding from Reliable Amplifier suppliers on AiyimaTechnology Store
Or better off without the op amp?
TPA3116 + NE5532
or this?
TPA3116 + TL072c
Cheap BT amps use audio signal from the Bluetooth module itself, signal quality is not very good. It is better to use a Bluetooth receiver that has a dedicated DAC chip inside.
https://www.ebay.com/p/BluDento-BLT...Blue-BLT-2/8028317188?iid=153331219158&chn=ps
Then add an amp.
Total cost will be a bit higher though.
Then add an amp.
