Class D BandWith DC to 10KHz
hello
I try to realize an amplifier with a bandwidth of 0Hz(DC) to 10Khz
I am using the IRAUDAMP7D (irs2092)
I simply remove DCP (dcprotect) and DC Block input capacitor
my amp goes into over current protec below 4Hz
Is anyone could help me to understand is mystery?
(I work in research and the amp is designed to control coils)
The best solution for playing very low frequencies and high power is to use two amplifiers in bridge mode (fed by the same PSU), this way bus pumping from one channel automatically compensates the opposite pumping from the other.
Otherwise with half-bridge designs you will have to use extremely large supply capacitors and you may gain little improvement.
