LOW ESR vs regular electrolytics. Not the main bulk storage in the PSU side but rather the smaller ones on the amp board next to the power fets.
From a HF design standpoint low esr caps rated for smps output duty should be used, but sound quality might object.
Which sound better ?
It's pretty easy to calculate the amount of ripple current that rail capacitors in a class D amp are subjected to - it's a lot. Use low ESR parts, it'll save you blown capacitors and a lot of grief.
A class D amplifier *is* a switching power supply, just with a modulated output voltage. All the good design practices associated with SMPS design are applicable to class D amplifier design.
As for "what sounds better", that depends on so many things to predict with any degree of confidence.
