Class d amp volume problem
Hi i managed my snake nest off cables
I use a minidsp and instead off using one amp for tweeters and one for bas/midrange.
changed so one
Amp does the left side and the other right side.
And strangely the sound is alot lower now
Before 48 volume was high and now 86 is the same volume. And it sound duller in both elements.
Can it be because off the impedance difference?
Tweeters are 6ohm and bas/mid 8ohm.
Checked the cables and everything i could think of.
Check the obvious - you are sending the correct signal to the correct amp input & connecting to the correct driver.
I assume you have speakers without crossover and are using one amplifier channel for tweeter and the second channel for mid/bass?
Connecting wrongly (sending bass signals) can blow your tweeters.
