I installed LJM L15D SMD ver3 and connected +-26VDC to the board.The board is not functioning properly.The LED light dims and the sound turns off.My questions a) Is the voltage low because the ad says it is scalabe b)is the board faulty and how to check.
Any help will be greatly appreciated
dvisves
dvisves
If you take the time to search the vendor forums for LJM's thread, I think you will find his minimum recommended operating voltage for that board. I faintly recall that you have to change a couple of resistors if you use low rail voltages like this, and you might want to try to track down the exact info on that.
