So I have an AB amp here that is working fine, but only putting out approx 265 watts rms into 4 ohms, and is rated for 500 watts rms into 4.
I know most manufacturers fudge the numbers, but just asking if there is any thing I may be missing.
Not sure what the rail voltages should be but all look like it is functioning as built.
What make/model?
What's the rail voltage at idle?
What's the 12v input voltage at idle?
What's the rail voltage at clipping?
What's the 12v input voltage at clipping?
