class AB amp clipping at 55v under no load, help
If it is not going over 55v something is wrong. Agree?
It can be a self oscillation that appears at 55v. Not likely as the output transistors dont get hot. Agree?
It can be a faulty component. Agree?
For instance if you have got a fake Q8. Where did you buy it? A 100v transistor can have a breakdown at 135v.
If you glue a coin as a cooler on a 2n 5551 it can do the job.
ok i'll try replacing Q8 it with MJE1032 and will check again ,,,
and cooling fan is already there for 2n5551
Try to decrease R13 from 1k to 470R, this will increase the gain by 6dB and improve stability if ever the amp is oscillating,
a gain of only 23 is not cautious given the IPS current and the 68pF compensation capacitor, another possibility to increase the gain is to just increase the 22k R12 resistance to 47k, this would be a better solution since at full power a 22k return resistance
has to withstand quite a lot of dissipation.
Reactions: hyperaudio_121
