Bad news, i accedently blew an output transistor because its heatsink came in contact with the other ones emitter resistor.
What do you think about using two of these: http://pdf1.alldatasheet.com/datasheet-pdf/view/38417/SANKEN/STA434A.html as output transistors pressed against a heatsink ?
They are from a stepper driver, but i think they should work for audio too, tho they are darlington but i don´t think that should matter.
What do you think ?
What do you think ?
Tekko said:Bad news, i accedently blew an output transistor because its heatsink came in contact with the other ones emitter resistor.
What do you think ?
I say you should not (can not) use those.
It is a totally different type.
Replace with original BD139/BD140, or MJE340/MJE350 which are in same TO126 class.
Eventually you could try some TO220 transistors, for example MJE15030/MJE15031.
And use your amplifier only for headphones.
To modify for driving loudspeakers, you need some experience to know what changes to make.
I know its an other type, its a darlington H-bridge but not connected to each other so i can easily hook them up as they were normal single darlington transistors.
I don´t have any of the transistors u suggested.
But if someone has a few over i´ll gladly take them.
The amp gladly drives speakers as is, i have played it loud and it doesent even get warm.
Now i have changed the broken transistor with a to220 i had in the transistors box, a 2SC1173 and it works perfectly, it doesent even have a heatsink and it barely gets warm anyway.
Glad you could make it work.
I would at least put a little piece of aluminium as heatsink at that power transistor.
Just in case.
Just in case.
The amp sees a total of 24v, 2x12v rails.
Now i have mounted the amp onto a bigger heatsink.
Please Schematic Diagram !
Sorry for my poor english !
They are Italian.
to be possible to have electric diagram of the amplifier Class A for
headphones of Elektor project Prelude ?
I have lost the magazine !
Regards.
Stefano.
They are Italian.
Regards.
Stefano.
Thanks ...
hi Marcos,
My email address is: kingtarkus@email.it
Excuse me for my poor enghlish !!!
More Thanks for the interest !
Regards.
Stefano (Genova Italy)
hi Marcos,
Regards.
- More Vendors...
- Elektor
- class a elektor headphone amp
