Class A amplifier watts
Doesn't it depend on load resistance??
If you wanted 1,000 Watts, and only had 30V supply, you figure 33.33 Amps. But 30V at 33.33 Amps is 0.9 Ohms, which is not a common loudspeaker impedance.
Also, we conventionally rate in Sine RMS, which brings in 1.414 and other irrational numbers.
And in this amplifier the idle current is half the peak current (not the RMS or Average current).
i am using 8r speaker.
Here is circuit.
For a push pull class A amp, the idle current should be the supply voltage divided by twice the load impedance - plus a bit to make sure it doesn’t clip early or come out of class A when the load goes below nominal. So figure an amp for 8 ohms, two for 4 on a 15 volt rail. More would be better if you can stand the dissipation.
For single ended class A you have to double it.
Some calculations above are somewhat optimistic, because they do not include real world transistor losses or only calculate dissipated power, not power into the load, or idle current is insufficient to maintain Class A at high power.
With 15V rails you can have, best case, 13V peak
Into 8 ohm:= 1.625A peak
Idle current= 1.625A/2= 0.8125A
Peak power= 13V*1.625A=21.125W
RMS power= 10.567W
So expected 10W RMS is *just* achievable.
Total dissipation will be 0.8125A*30V=24.375W
I've got some HUGE heatsinks here if you are interested.
I used two of them to build a lovely Pass Aleph J.
They are very heavy so would be better collected from B98.
The wood work isn't included, it just shows how I used them.
