Hi all, trying to repair a Clarion Apa4300 amplifier.
When attempting to power up the digital panel lights up,
The power on led stays off.
No audio output.
On internal inspection Q143 tested 0 ohms across all 3 legs so I removed it along with Q144
I've tested TL594, all measurements in DCV pins 1-16
1, 0
2, 4.9
3, 0
4, 0.1
5, 1.5
6, 3.6
7, 0
8, 12.9
9, 6.2
10, 6.2
11, 12.9
12, 12.9
13, 4.9
14, 4.9
15, 4.9
16, 3.5
Also checked dc voltage on Q812
1, 12.65
2, 13.6
3, 13.3
Apologies I had already started a post on this amp but my meter was on the wrong setting leading to much confusion so I've started a fresh thread.
Hopefully I can get the amp up and running again, and thank you Perry for your patience and support.
No audio output.
1, 0
2, 4.9
3, 0
4, 0.1
5, 1.5
6, 3.6
7, 0
8, 12.9
9, 6.2
10, 6.2
11, 12.9
12, 12.9
13, 4.9
14, 4.9
15, 4.9
16, 3.5
1, 12.65
2, 13.6
3, 13.3
The IC is producing output. Confirm that you have ±rail on the output transistors and ±regulated voltage on the op-amps.
Do you still have 6v on pins 9 and 10 of the 494?
What is the DC voltage if you place the black probe on pin 4 of the op-amp and the red probe on pin 8?
- General Interest
- Car Audio
- Clarion amp, not powering up
