10r won't do much limiting in a 220Vac system.
10r is excellent for 110Vac systems.
Too bad Andrew passed away. 🙁
Can someone please suggest the correct NTC value for 220VAC?
Same here though I use 2 in series, which I think was mentioned in the f6 build guide. if you want to play it safer I don’t suppose there’s any harm adding another cl60 in series, bringing the total to 30r?
I have looked at this from RS Components. Specs looks look the same:
RS PRO Termistor, 10Ω ,15mm(Dia.) x 6mm. Nr:516-7827
https://dk.rs-online.com/web/p/termistor-ic/5167827/
