Mouser has circuit board standoffs.
If they don't have what you need, do an image search for:
to see if you find what you want.
If it's already connected, it probably won't benefit from a second connection to the chassis.
Is there a hole under the via in the photograph you posted?
I don't think I'd ground it again (risking a ground loop) but there are nylon standoffs that will give additional support.
If you find that it needs a connection to ground, you could always use a wire to make the connection.
- General Interest
- Car Audio
- Circuit board stands
