CIARE 15.75NdW2 - 15” woofers
In perfect new condition, only 8 hours of use! Special OEM version with coated cone, this gives an even smoother response than on the datasheet. Kapton voice-coil former. Double neodymium magnet. Die-cast aluminium and magnesium frame.
THIELE-SMALL PARAMETERS
Re (Ohm) 5.75
Fs (Hz) 36.95
Cms (m/N) 0.000207
Mms (Kg) 0.08975
Qms - 20.04 😎
Qes - 0.29
Qts - 0.28
Vas (m3) 0.212
BI (Wb/m)20.46
S.P.L. (1W-1m) (dB) 99
Xmax (mm) 4.5 (*)
Sd (m2) 0.085530
Total of 4 pieces for sale. € 249,- each (new price € 345,- each)
datasheet
(tweeters not included)
Re (Ohm) 5.75
Fs (Hz) 36.95
Cms (m/N) 0.000207
Mms (Kg) 0.08975
Qms - 20.04 😎
Qes - 0.29
Qts - 0.28
Vas (m3) 0.212
BI (Wb/m)20.46
Xmax (mm) 4.5 (*)
Sd (m2) 0.085530
datasheet
I'd love 'em, but there is this silly ocean in the way. I am planning on coming to europe at the end of the year, maybe I could go through ams and pick them up then check them on the plane. Don't hold them on my account though.🙂
Send me a mail when you know exactly when you're coming to Europe, if I still have them then, we could arrange something. 🙂
