Good afternoon to the friends of this forum is from Brazil and I am needing a ci dspc56371af180 to repair my receiver Pioneer tried already of all the ways buys lo here he/she doesn't have the only form would be somebody of out of Brazil to send me the piece.
If somebody can help mine
Zip code in Brazil is 22790702 - I laugh of January-brasil.
A ci is just enough
Thankful
mauricio
A ci is just enough
Thankful
mauricio
If it's a microcontroller, you'll also need the firmware and some way to program it. But those parts rarely fail. Make sure it's not something trivial like a bad power supply or reset circuit.
I already tested all of the sources everything works more he/she doesn't leave sound, in agreement with the manual service of the apparel in the pin 54 of this ci should have reduce to zero volt and he/she doesn't have, in that case I must change him/it, they put has a memory ROM where this his/her programming.....
Actually I need another new ci even......
Thank you
mauricio
Thank you
mauricio
