Hello everyone, this is my first post so go easy.
I've been looking into building speakers for a while as a hobby and this year I have the space to start.
My question is when looking at driver's (in this case full range) what specific information would tell you a good driver from a bad one?
For example, 2 different 4" driver's, one costing £15 and one costing £40. How could you tell them apart in terms of quality apart from the the obvious cost difference.
Like I say I'm new to this so go easy, I'm here to learn
Many thanks
Many thanks
Choosing drivers is in many cases a bit risky. Sometimes measurements are looking fine for both speakers and one can sound not so impressive like the other one with similar specs.
Also there is a need to have answers for some questions, like how will you power the speakers or how much space do you have for listening and how does it look like? Also what kind of music you will be listening to on those speakers?
Cheers
Cheers
FR drivers, (& enclosures ?)
Hi there: Recommend a starting point by clicking on the Full Range threads here on Diyaudio. There is a wealth of information there. You will get exposed to many opinions on drivers and enclosure types. As others stated in earlier posts here, there is no one best solution. FR divers are relatively inexpensive, so try some out (mono?)...Michael
For example, 2 different 4" driver's, one costing £15 and one costing £40. How could you tell them apart in terms of quality apart from the the obvious cost difference. Like I say I'm new to this so go easy, I'm here to learn. Many thanks
First, don't let low price fool you into thinking a driver can't sound good if it doesn't cost a lot. There are a LOT of drivers that are inexpensive, but sound great.
In my opinion, starting with Mark Audio drivers would be a good way to go. There are a lot of other good drivers, but in my opinion, you get a lot of bang for your buck with Mark Audio drivers. Plus, there are a lot of designs for them, with varying degrees of difficulty, from very simple to very complex.
Others will, I'm sure, disagree. However, as a guy who depends on the designs of others, I know Mark Audio works extremely well for me.
The CHP-70 is one of my favorite drivers and is inexpensive. A FAST or WAW is good option and relatively simple.
Once we know a little more info, we can make suggestions.
Welcome to the addiction!
Mike
Mike
One really has to listen to them, specs only tell you so much, and sometimes the wrong things…
dave
I agree.
And sometimes even specs are wrong.
Either by intent or one simple typo or even more.
This is a good way to start. When I began looking at "fullrange" (wideband really ) drivers I wasn't aware of this forum, so began with general internet searches. There used to be a site called "fullrangedriver.com" You will need to use the Wayback Machine to access it but it's well worth it. Published driver specs will not help you much, you'll need to do a lot of reading of other people's impressions and try to choose what to believe, that is assuming you don't want to someway or another listen to them all yourself Single Driver Website FullRangeDriver.comRecommend a starting point by clicking on the Full Range threads here on Diyaudio.
+1 for MarkAudio drivers.
I've listened to 4" Fostex drivers and also Peerless 4" drivers and finally bought a pair of Pluvia 7's for a pair of BLH's. Man they were an 'ear opener'. Quite a difference from the previous 2. Don't rule about 3" full rangers either. MA has a very interesting Alpair 5 Gen 2 driver.
But as far as looking at a spec/datasheet, maybe some warning signs would be dips or peaks between the critical 1kHz-7kHz range. Especially dips or peaks at multiple harmonic frequencies or even larger dips or peaks at a single frequency.
Also, a higher efficiency driver at a cheap price might be a warning sign. Probably should be used in a multi-way speaker config instead of full range.
Mark Audio are not so easy to source in the UK.
I don’t think that is true. A distributor in Warwickshire. http://www.kjfaudio.com/
They also sell flat-paks. FHXL for instance likely more available than anywhere else.
dave
dave
Thank you for that information. A very useful site. Happy to be corrected.
- Full Range
- Choosing driver's
