Choosing a relay for loudspeaker switching
The point is that on opening the first to open see no stress. The last of the contacts to open sees the full duty of trying to break the circuit.
It's bad from safety perspective, if it welds. May be we can factor that while selecting individual contact rating.
But isn't it good from long term degradation perspective? Because it's likely that only a single contact will continue to get corroded and the other contact will continue to provide clean signal path to low load?
If one contact can weld, then you don't have enough contact, imo.
Also the type of the contact shape matters, as does the contact material... crossbar is likely best for audio, IF you could get it...
My thinking is that no matter what the contact being used, more in parallel will provide substantial reductions in terms of the issues inherent in relay contacts. One can assume for the benefit of discussion that we are comparing one "adequate" contact to multiple contacts ("overkill").
I prefer the "overkill" approach, IF the signal is required to flow through the contacts, as opposed to being a path to shunt a signal to ground for turning off the signal path/flow... (that's not the same as providing a path to ground that will enable a circuit to operate).
Just my experience talking here, that and what I have read in passing.
_-_-bear
