Hi.
Please forgive me if this is answered elsewhere, but things move so fast in this field.
I'm considering making a classD amp for a active speaker and the requirements will be something like this:
Ideas for implementation:
Will the IRS2092 IRAUDAMP7S be the best starting point:
https://www.infineon.com/dgdl/iraudamp7s.pdf?fileId=5546d462533600a40153569addc92bfb
Any inputs are welcome.
Kind regards TroelsM
- 100Wrms, 200Wpeak @8Ohm, 200Wrms, 300Wpeak @4Ohm
- Double-sided homemade PCB
- Stable: as in not blowing up and killing speakers
- mid-fi performance: no need for HighEnd, as we are talking semi-PA.
- Low EMI: it will placed right next to the PSU, filters and amp for an sensitive treble-horn.
- Overcurrent-protection is probably not needed, but would be a nice feature.
- DC-protection would be big plus
- What other protection do we need for a basic classD?
- Thermal protection, limiter and distortion-indicator will be added.
- runs on unregulated or regulated LLC-smps
- Most likely discrete TO220 mosfets (more options than the integrated packages)
- Torroid output-inductor (because I have them)
- Maybe a seperate driver-board for the IRSXXXX ( if it would make the PCB-design better
- Ground/Vss-planes
- SMD-resistors and capacitors (1206-0805)
- Some sort of LC-filter on all connections
- A few 330uf/100V caps on board
The best DIY Class D design you can get:
SystemD LiteAmp
I have build a 4 channel bridged (8 amplifiers). Sounds excellent and is powerful, safety, proven.
Best regards, Toni
SystemD LiteAmp
Best regards, Toni
... then SystemD lite amp meets exactly your needs.
Chocoholic has given many tips and hints for pcb design too.
My 4 channel bridged "SystemD lite" based amplifier makes really fun not only at high power levels - even at 1W power level it is really a performer!.
Have fun,
Toni
Have fun,
Toni
ASTX: I would like to avoid bridge-mode to keep parts-count down. I know that there are some benefits from the bridging, but 250W/4Ohm should be doable without bridge. - especially if I can sacrifice some hifi-performance for durability.
I don´t see any ferrite-beads/LCL on the connections to LiteAmpm - but maybe the noise is kept all internal to the PCB?
- Class D
- Choosing 200W class-D type
