Yes, and the iron is very small too!I would also doubt the 50A figure. It would have to be 4.6mm wire to achieve that.
Tyimo
That is a BIFILAR choke they somehow work differently. There was a little talk about
this in a thread about using a choke input filter for the zen amp. Someone had found
bifilar choke that looked good for a choke input filter and was informed it just wouldn't work. But back to the discusion of size. I have a 12A 4.8mh choke and it's
about the same size as that one in the picture.
I'd be surprised if Hammond would be willing to risk their reputation with false or misleading performance data. The choke is supposedly wound with large gage wire. Judging from the impedance, I'd be incline to believe them.
The choke never overheats, unlike my hand wound choke (11 gage wire) which ran up to 90C and didn't offer as much bass.
At any rate, these units sound excellent in my little amplifiers.
Bifilar is nothing special.That is a BIFILAR choke they somehow work differently.
You can use serial, paralel or balanced the wires.
I serial the induction will be doubled.
In paralel the induction wilbe halved. etc.
I have also one somethig like yours. Made with an EI150 iron and wery thick wire.I have a 12A 4.8mh choke and it's
Tyimo
This is the most important!🙂At any rate, these units sound excellent in my little amplifiers.
Tyimo
Yes. And with a simple thin wire and small iron I can't believe that it has 300mH with 50A! Maybe 2-3A and not more...but it is enough...
The choke shown in post #18 is not rated for DC use.
Good start... do go on.
Most likely , a choke without an air gap (hence the 300mH) and wound with multiple wires to achieve the 50A rating. Hammond is a reputable company.
Right on both accounts. With an air gap the inductance is 50mH. I have one and it reproduces music very well down to 100hz or so. If I build amps for the sole purpose of reproducing midbass and up, then that's the way I'd go. Problem is, you have to purchase in $1000.00 minimum lots, and the 300mH is all I could afford at the time. The 300mH does an extremely fine job in my particular application (cascode with the tranny in follower mode). Ellen, my golden eared sweetie, swears it's the best sounding amp I've built so far--one can learn a lot from Nelson Pass' tutorials.
Depends on the circuit, but at 20 Hz, that value is 40 ohms or
so, which is plenty enough.
You lost me... do you mean 40 mH?
for my ( careful - ZM's ) logic - Papa meant :
"at 20 Hz , impedance is 40R ..... "
Just thought I'd mention: the wire is not round, it's rectangular. You're seeing the small edge, not the wide.
funny woodie - now you are saying that ......
It's interesting to observe, isn't it? People assume Hammond isn't on their game. I think their engineers are rather clever.
I think I have figured out the answer to my own question.
End-stacking two inductors is the equivalent of two sets of windings on the same core. Double the number of windings should quadruple the inductance (which it does). Reversing the magnetic polarity improves the AC saturation, but not the DC saturation. Therefore I don't think it is the best solution for a SE class A amplifier.
The choke in #18 looks like an AC powerline choke, and may not do well with a bunch of SE class A idling current. If anyone has an idea (or can link to a discussion) of how to evaluate an AC choke for this use, please share it with me.
It looks like I need something like this (for 400hz 16 ohm) :
Digi-Key - CH-2-ND (Manufacturer - CH-2)
- Chokes for SE class A
