Choke vs inductor
The condenser was across the points to suppress arcing. No points, no condenser. It condensed the spark?
Looking at my ARRL handbooks back to the 60s, I don't see a differnetiation. Same with RDH 4, both references are used with choke following a the type of inductor.
1946: https://maritime.org/doc/radio/chap10.php
"The subject of this chapter has two names-CONDENSER and CAPACITOR-and both names are OK. A lot of hot arguments go on over which is the correct name. Some men argue, and probably rightly so, that the name CONDENSER is wrong, since NOTHING is CONDENSED. ........."
https://maritime.org/doc/radio/chap9.php
"COILS and TRANSFORMERS, while much simpler in design and containing NO MOVING parts, also depend upon INDUCTION for their operation. ... Many coils and transformers have special names, such as CHOKES, POWER TRANSFORMERS, INTERMEDIATE TRANSFORMERS, INPUT TRANSFORMERS, and many others. It will not be unusual to hear all coils and transformers called by a general name of INDUCTANCE or INDUCTOR."
Reactions: exlabs
Starting with Post # 1, and continuing all the way to Post # 22, I have not seen a detailed description of what this filter is to be used for.
Switching power supply DC output low pass filter?
20Hz to 20kHz Bandpass filter?
Some other application?
Example:
A filter for an efficient switcher that is at a 25kHz rate, there may be harmonics out to 500kHz or more.
By the way, there has been no discussion of what frequency the filter capacitor impedance is minimum, and what the inductive reactance of the capacitor is above that frequency.
If you are designing filters, do you know what a re-entrant frequency means?
Optimal filter designs are not simple.
Reactions: merlin el mago
It’s funny that you hear coke, common mode or differial choke but I’ve not seen a common mode inductor or differential mode inductor.. although i have s ferrite common mode inductor (designed for 25MHz).
It’s a bit like transformer and Balun. Just seems a specific purpose has it’s own name for what is a impedance matching balanced/unbalanced centre tapped transformer.
Reactions: exlabs
Often it is just a continuation of what generic label was attached many many decades ago for a particular group of parts for a particular application. As with labels like Balun, and RFC, the term Ballast has generically labeled the iron-core inductor used for current regulation in fluorescent light fixtures and btw make excellent chokes for 'choke input' mains frequency dc output power supplies as well as CLC filters in such power supplies, as the SRF is typically significantly higher than in a nominal EI core choke and the safety/insulation is designed for a 250Vac mains application.
That’s for link, they seem good. I wanted to avoid air core, because of size, it also seems they are more expensive. Also concerned about the large magnetic fields size of air cores as I have other magnetic components nearby. That’s why I suggested the two I did above, I know they won’t saturate as well.
From what I understand above it was spoken somehow in semantic terms.
In Italy, eg to define what the Anglo Saxons call "choke" it is simply called filter inductance. We do not have an equivalent term in Italian. In general inductance is used for something big, with core, etc while inductor is mostly a component on circuit, smaller.
French people instead call "bobine" (bobbin) to define various elements, eg. reactance bobbin, HF blocking b. etc.
Reactions: exlabs
35 Posts, and we have heard all about inductance, inductors, chokes, reactors, laminations, air core, air gap, saturation, distributed capacitance, resonance, bandwidth, etc.
Now . . . let's hear about how the Original Poster's Filter is progressing.
Is it designed?
Have the parts been ordered?
Is it built yet?
Did all of you forget what this thread was about in the beginning?
....... I’m making an LR filter, I need an inductor of about 2mH and it will pass about 1.5Arms. This is an audio filter so will operate between 20Hz-20kHz
Some options from Bourns:
5700 Series High Current Inductor and the 1140 Series High Current Choke.
The 5719-RC Inductor 2250uH (at 1kHz)
The 1140-222K-RC Choke 2200uH
Imho the original post should remain unedited, except perhaps for adding a clearly identified addendum, or better still by adding a new post with new details/conclusion, otherwise it is difficult to review the thread in years to come and make sense of it.
Just stating it will operate between 20Hz-20kHz may well be a naive comment for some applications, so I'd suggest the actual use details be provided so that others have some confidence that any technical response is actually covering all aspects of operation that should be reviewed.
One concern is that those linked datasheets show no technical detail relating to the anticipated simple 20-20kHz use, and you have made no comment on the +/-10 or 15% inductance tolerance, or the 5701 specs relating to inductance variation with increasing ac current (ambiguous as to whether that is included in the +/-15%), or if there is a dc current component aspect to the application.
