That's a common-mode choke, and not suitable as a PS filter in this application.
Roscoe
nope common mode type choke work even better in psu....
A core that size, especially a toroid, isn't going to handle anywhere near that much current...
Try the Hammond 159ZE, a bit pricey, but well worth the money...
Roscoe
Roscoe
differential mode choke ( big one ) is the way to go
How "big" would be the smallest recommended for 3A per channel current capability?
THX,
-Joe
big in value , or big in size ?
lookielookie : http://www.diyaudio.com/forums/solid-state/161663-nem-ai-50-a.html#post2144101
observe value of L2
hop to 6moon article , read , study CRO photos
use PSUD to decide what's enough for your particular case
observe value of L2
About the size of the previously mentioned Hammond 159ZE....
Digikey's website shows the 159ZE as L= 28mH, Imax =3A and R= 0.43 ohms, and costing $28 and weighing almost three pounds! 😱
Since NP suggests 1.5-2.2mH, I will continue looking for a suitable surplus toroidal unit...
-Joe
I've been running a lot of PSUD simulations recently on choke input filters. Sometimes I get a warning that the rectifier reverse voltage has been exceeded. The voltage spike comes right at the zero crossing of the transformer voltage.
Usually the big peak in transformer current comes after the transformer voltage peak. (Current lags voltage in an inductor.) If you get the load current and capacitance just right, the current peak is very near the center of the voltage peak and looks like the current peak you normally see with capacitor input filters. No spikes. If you put a smallish capacitor on the rectifier side of the choke, you can increase the voltage between the choke input value and the cap input value. The problem becomes finding a cap that can withstand the ripple current.
Power factors (power out/power in) run about 60-65% with cap only or CLC filters. About 10% higher with LC filters.
Note: To get PSUD to spit out valid RMS numbers, run the simulation for 100mS to get 5 complete cycles at 50Hz or 6 complete cycles at 60Hz. Then you get pretty good numbers for the currents in all the components. There is also a feature that lets you calculate the transformers bulk impedance from the winding resistances and no load voltages.
I use a 2 second delay, but you can get a big voltage spike at turn on. Check what goes on with zero delay. I guess I'll be shopping for thermistors soon.
Thermistors specified by Mr. Pass in my circuit
Absolutely. Thermistors were specified by Mr. Pass in my PSU circuit.
Does PSUD simulate use of one CL 60 on each primary line lead to traf?
If so, how does this affect the peak voltage on rectifier(s)?
Thx,
-Joe
P.S. Loudthud:If you want I can send you a spare pair of CL60 I have lying around(PM me).
Thx,
-Joe
Hi, I would like to rebuild my Aleph's 3 PS to CLC type and I've got one question. Can I use one choke on PS-GND rail instead of typical two on positive and negative rail?
been there ...... I also had 2 beautifull ones , but placing them in gnd rail is non-effective ..... sum if current is zero
good to know, thank you 🙂 Will buy four smaller then. Do you have any Aleph 3 tricks, more than PS? Actually Ive got pin to pin Aleph 3 clone built by me. They are JIMS boards on IRFP244.
- choke input power supply filter
