choke for output inductor
Stoc no. 2011474 - Cast filter chokes with iron powder cores freq up to 500 kHz. The one on 25 uH/2.5A might do the job .... but note 2.5A only .... not much!
Stoc no. 2011475 - INDUCTORS DESIGNED FOR NATIONAL’S 50 KHz SIMPLE SWITCHER™ ........ You would need one of the smalest values like the 47 uH/3A ..... but the intend to 50 kHz will not be enough for a good D-Amp, and will probably heat up.
Stoc no. 2011476 - No good as these are ment for 50 Hz/240 V filters
Better still would be to go for vinding one yourself. I have just ordered some T106-2 and T200-2 RF cores from Micrometals, which can be had for a few $ at:
Kits & Parts
You can download a design program from Micrometals
Calculating a filter can be done here
PS. Your links to the coils in this post does not work🙁
Maybe i can use the T106-1(or whatever they are) cores i already have, the ones from the puter ps output filters.
Maybe 15 turns would do.
Hum i tested the proggy, according to that i need 37 turns, if the cores i have are T106-2.😕 😕
