choke current rating
Agreed, a 100mA choke is fine. The unspoken assumption is that the choke is followed by a capacitor that averages those 20 - 160mA swings to 80mA. In general, chokes tend to be rated by the maximum DC current that can be drawn through them, and the inductance is often given at this value of current.
Beware that a choke input supply can cause a peak current through the choke that is rather higher than the DC load current because of the AC current flowing through the choke and to ground via the following capacitor. PSUD is very handy for quickly checking this. The choke's rating needs to be greater than the peak current in operation.
OK. So we need to select a choke rated for dc current only (this is the way it is designed, and it is logical then).
> Use a very good quality (and over-spec'd) cap for choke input
> supplies - otherwise they tend to buzz like crazy!
Film capacitor like solen is good enough ?
What is the effect of power supply transient response ? Does it need to be overdamped or underdamped or does it matter ?
Radiatron designers handbook says the inductance of the choke must be greater than (Rs + Rl) / 942 (that is for 50hz). Do you use this formulae to select choke value ?
This may be a language problem. Chokes are usually rated for DC current, but just because you are passing a DC current within their rating doesn't mean that you can't overload them with an additional AC current. The current peaks must be less that the DC rating.
Any old rubbish capacitor will do. (I just know that this will incur the wrath of the gods.)
An LC filter in a power supply is a resonant circuit. Whether it actually rings is another matter. My personal opinion is that things that ring are not good, and should be avoided - critical damping is a possibility (Q = 0.5).
You'll need to give a page reference for your RDH comment.
Ok. As in the book "Valve Amplifiers by Morgan Jones", choke must be rated for Idc + Iac (peak) ? But is this value rated DC current or saturating DC current or neither ?
For example, in hammond catalog, enclosed DC filters (chokes) have specifications below:
- Inductance
- DC Current
- Resistance
- Maximum Operating Volts DC
Lundahl LL1638 have specifications below:
- Inductance
- Recommended DC Current
- Saturating DC Current
- Max Ripple Voltage at recommended DC Current
- Resistance
- Isolation Between Windings/Between Windings and Core
What I understand here is:
- Inductance = Inductance value when specified (recommended) DC Current drawn.
- (recommended) DC Current = Recommended DC Current that must be drawn for specified Inductance. (less or higher value will change the inductance)
- Saturating DC Current = Maximum DC Current that can be drawn from this choke. Exceeding this value will prevent usual behaviour of choke.
- Max Ripple Voltage at recommended DC Current = Maximum AC voltage that is not harmful for this choke.
- Resistance = Resistance of choke.
- Maximum Operating Volts DC or Isolation Between Windings = Maximum DC Voltage that this choke is permitted to work. Exceeding this value will destroy something.
Here there is no reference to Iac(peak) of the choke. Only specified AC parameter is Max. Ripple Voltage at recommended DC current.
Why do you think ringing is not good ? I need some technical explanation why or why not it is bad in a power supply designed for audio power amplifiers.
RDH: Chapter 30- Section 3 - Page 1182.
Thanks...
MB
Saturating current, AC, etc: The issue has been somewhat confused by some iron manufacturers who have designed chokes for a specific choke input supply yet only give the DC load current rating, rather than the true current rating of the choke. In their defence, they frequently have customers who don't know how to calculate what's going on. It's also not helped by the fact that although iron manufacturers know about winding coils on iron, they very rarely know anything about electronics, so explaining how you are going to use the iron doesn't always help.
At the end of the day, an iron choke has a finite number of magnetic dipoles that can be aligned, once they have all been aligned, the iron choke is saturated, and it doesn't matter if this was done by pure DC or pulses of AC. The magnetising force that causes saturation is measured in Ampere turns, and since the number of turns on the choke is fixed, it follows that a given current causes saturation. Unfortunately, flipping those very last magnetic dipoles is difficult, so saturation doesn't tend to occur abruptly, it's more of a gentle knee, and that's why there are so many definitions of when saturation occurs. Play safe and keep below the maximum DC operating current, and you should be fine. As you enter saturation, inductance falls, and the effect on a choke input supply is catastrophic because it causes even greater AC current to flow, driving the choke harder into saturation. This can often be the cause of buzzing that a previous poster noted.
Why do I not like ringing? Would you like your amplifier to be supplied from a source that isn't constant DC but might bounce up and down by tens of volts?
The RDH equation refers to the "critical current" of a choke. Leaving the rectifier is a waveform composed of pure DC plus a series of harmonically related AC. The output of the choke is short-circuited to 0V by the following smoothing capacitor, so the choke draws AC current that is inversely proportional to its reactance at the AC frequencies of interest. Obviously, if there is AC current, at one instant it will add to the DC load current, and at another, it will subtract. The critical current is the DC current required to ensure that the AC current never causes the total current through the choke to fall to zero.
Adding a bleeder resistor helps with the size of the choke if the load current is low, but wastes power. If you have a variable load, then a swinging choke might be a good idea, otherwise, it's time to rethink the design.
Hope this helps.
choke values
hello
try to get more information from the manufacturer. Older types give the Henries with no dc and max dc for the rated power losses.
Or the values are explizit given in Henries at the spezified value of dc, like 10H@100mA.
With curves you can choose the right choke by Henries, dc and power losses, voltage drop at the used current...
look here
an example:
What is the disadvantages of putting a bleeder resistor in parallel with the load in order to decrease required choke size ?
The advantages far outweigh the disadvantages. If you are using a choke input filter, bleeding 10% of the load current will help a lot. In your case , I'm guessing a 40K ohm 10-20 watt resistor would work. I personally like to bleed off as much as the power transformer can stand without getting too hot; even in class A this type of brute-force regulation is advantageous.
John
While I entirely concur with the above, this is also where I often like to waste even more power by doing away with the resistor and use a shunt regulator instead for a money no object project.
"Slam" fans, take note...😉
Cheers,😉
