chip reg with ext voltage ref...?
it has just come to my attention that it is possible to use an external voltage reference with a chip regulator - 3x7 or 108x types....
i have never seen that before, how does it work? is it better?
thanks,
troels
:scratch: :faint: 😉
chip reg
The 723 is very, very old and tired. It has a mediocre, 741-type error opamp with very low bandwidth, and the reference isn't up to modern standards either. This would not be a good chip for your high performance regulator.
The others as mentioned have internal references and I don't know of any way to disable them. Even using a 317 with separate error (feedback) opamp driving the adjust terminal will still have the internal ref voltage in series with the opamp output.
I think you have only the choice between a fully integrated regulator or a discrete approach with ref, error amp and pass transistor. This last option undoubtedly gives the best performance. Anything in between is, well, in between.
Jan Didden
I only point out the '723 as it readily came to mind as having an external reference.
For now I just use LM317LZ's with outboard current maintenance. Perhaps I got a really good batch, but the noise is de minimus.
In my HV regulator circuit I am using a Maxim 6250 with the Maxim 5250 DAC -- a little inconvenient as it's an 8 pin DIP, but they seem "made for each other".
Please correct me if I am wrong, but my understanding is that
any three-terminal regulator can be used with the reference
pin tied to an external reference, since the regulator adjusts
the output voltage relative to the reference pin voltage. For
a 317 we get Vout = Vref + 1.25V for instance. The reference
voltage source must be able to sink some current (about 150uA,
I think, for a 317) and it may be wise to include a protection
diode from ref. pin to output. Basically, this is the same
principle as can be found in application notes where a zener
diode is connected between ref. pin and ground to get
higher input and output voltages than usually allowed.
Jan,
yes, I completely agree, but the original posting didn't say
anything about the context of use, or why an external reference
was to be used. I admit, though, that in most cases there will
be no reason to use an external reference. I can think of two
reasons, either we want to use the regulator for higher input/
output voltages than it is rated for, or we vant to set the
output voltage with a voltage rather than with a potentiometer,
for some reason.
