Chinese copper with teflon u cap capacitor
Hello i know that some years ago same topic was started, but which no answers, and it is closed for now. So did any body tryed, or compared chinese u cap? Is it realy made from copper foil and teflon? Dimensions and weight is near v cap cutf version. Please help me.
I think I will try these. The mpt and the mkp both, you can tune the sound of the speakers for sharpness with these maybe. From AliExpress
Which "them"? It common for different, cheaper, items to be substituted on a re-order for nominally the same item. If you need copper/PTFE, buy from a supplier who wlll supply whats on the datasheet (oh yes, is there a datasheet?), else expect to be fleeced (then you won't be dissappointed).
I would compare the dielectric strength of Teflon and polyester film (which I think is the normal dielectric material), and insist on a datasheet from a traceable manufacturer, with ISO details.
The ISO certification means a lot of QC is in place, and the maker is actually making them in a way that is recorded.
And I think copper is a lot less flexible than the metallized film normally used in capacitors.
The things are said to be hand made, further cause of inconsistent quality.
I am skeptical, but without actual user feedback, hesitant to call it snake oil.
Maybe Copper does not oxidize, and can be rolled thinner than Aluminum?
As a non magnetic material, yes.
But that would lead to a never ending debate.
Like the use of hemp and silk fibers in audiophile capacitors, that subject has many opinions about it.
Copper oxide is a semicoductor, aluminium oxide is an insulator, you might worry about non-linear effects with CuO perhaps? Though I suspect oxidation inside a cap is minimal.
Any moisture-absorption in a dlelectric material leads to higher losses and capacitance drift as water molecules are very polar and mobile and have a large dilelectric constant that varies markedly with frequency. Its no accident PE, PP, PS and PTFE are low loss dielectrics, they absorb very little moisture as they are non-polar polymers. Hemp and silk are moisture absorbing so make poorer choices for a dielectric.
Very thanks for lots of informations, but this dont help me at all. The question is to persons that have this u cap and have compared to other cap.
So you want to read someone's comparison of this and other capacitors, even though the rest of their system may be totally different from yours? I admit I don't have the best Golden Ears, but my ears aren't discerning enough to be able to tell whether a difference in sound between two systems is due to the capacitors or what.
I did find a couple of links:
https://www.aliexpress.com/i/2255801096595049.html
http://www.ucap-audio.com/ucap.html
I think I'll stick with Digikey and Mouser, and not go looking for "audio" capacitors.
