Check this 7" screen out. Need feedback
Wow. And here I was thinking this was the ump-teenth time somebody was posting a link to a 7" monitor with 280 horizontal lines for $300+. If that res is correct, that is probably the best panel I've seen so far for non-fresnel true DIY projects. The price is certainly right.
Ah wait, the catch. It doesn't say if it has a VGA input. I would be skepitcal if that's the real resolution, and is it really worth the time, money, and effort for something with nothing but a composite input?
verbose mustafa said:
Thats is the resolution counting each dot...
Not taking into consideration the fact that 1120 can't divided by 3 without a remainder (1120/3 = 373,3333.....), how do you explain the calculated "real" resolution of 373x480 for 16:9 screen?
Anyway, I admit that something is bad with the specs, since the resoultion of 1120x480 doesn't give us a desired 16:9 aspect ratio either, unless dots are not square.
