Seen some for about $2000,-
Well, Its really a 3D- mill, but what about a machine that can even make the PCB for You?
Ebay somewhere I think.
I don't need a machine that will mill an entire PCB, just drill the holes.
40-50 holes?! I thought I needed one when I had to drill three boards for each kit I was selling, with a total of about 3000 0.032-inch holes. But I usually only put together 10 kits at a time, and only sold a few hundred of them, total. So I couldn't justify buying one. It only took a little over an hour to drill a set of boards by hand. I used a cheap dr9ill press with a Dremel hose-clamped to it. It wobbled pretty much, so I wrapped a long spring around the tool and connected it to the drill press's post. Perfect!
Eleven years ago, I did investigate designing and building one from scratch. I actually built one but got busy and never mounted the Dremel flexible shaft drive head on it, or hooked it to a computer, although I ran the axes with a pulse generator a few times. I bought a few big old heavy dot-matrix and daisy wheel printers, and a smaller one, for $5 each, and made this: http://fullnet.com/~tomg/gooteecn.htm . I think maybe I decided the resolution was going to be a little too low. It was something on the order of a tenth of a hole diameter.
So I would probably do it differently, if I tried it again. There are lots of plans and deisgns and ideas for them, available on the web. I also bought a small x-y milling table, back then, from Harbor Freight, that would probably have worked for positioning the board, and would have had better accuracy. I never got around to mounting stepper motors on it, though. For something as light as PCBs, it wouldn't be too hard to build one from scratch. Even plain threaded rod from a hardware store, and some coupling nuts, would work, and could have good-enough accuracy, theoretically, with 200 step per revolution motors and 24 or 32 threads per inch rods. Think about using the concave rollers that are sold as replacements for sliding patio doors, for your x and y platforms to roll on (on smooth rods). Or maybe use drawer slides. There are lots of ways to do it. The basic idea is to attach one or more coupling nuts (long nuts, as in an inch or more of threads) to the platform. Then, when the threaded rod is turned, the platform moves. There is also Acme Rod, and Ballscrew Rod. They are more accurate, and have less backlash, and won't wear out nearly as fast. But the coupling nuts remove almost all of the backlash (and the rest can be removed in software). And they are so cheap that you can simply replace them more often and still come out WAY ahead.
I also bought some old pen-plotters, back then, to see if they could be used, somehow. I believe that some of them would work, to position the board, too (but some are a little flimsy-looking) I even have some old ANALOG plotters, made my HP. Wow those things have scary-fast slew rates. They have manual modes, too, like a giant electric Etch-A-Sketch. Really fun to play with. They would work great, too, and have MUCH stronger motors than the more-modern (but still basically antique) digitally-controlled pen-plotters, like one by Roland that I still have, but would need D-to-A converters and interfacing for computer control.
Thinking about it just now, I would probably try to go with a tabletop-size milling machine, since it could also do so much more. But you have to find out how to tweak the el-cheapo ones, to get rid of run-out, and other sources of inaccuracy. That's all on line, too. Check yahoogroups.com . Everything you need, for ALL of these kinds of projects, in already on there.
Actually, the milling machine would NOT be ideal, unless you could get one that ran at 30000 RPM or so. The Dremel-type rotary tools work well with the solid-carbide PCB drill bits, which can last for thousands of holes, unless you break them, which is all too easy. So you probably need something that can use a Dremel-type tool to run the bit. On the other hand, maybe the Dremel flex-shaft drive could be attached to the milling machine's spindle assembly, somehow, with the Dremel itself just hanging overhead, and maybe you could run the milling machine without its spindle turning.
The Silhouette Cameo CNC paper cutter, available at ~U$270, has been adapted by a number of people to use as a mill/drill.
PCB Mill&Drill - YouTube
Quick Printed Circuit Boards - Microsoft Research
Oh, the way to generate tool paths is to use pcbgcode, an add-on for Eagle developed by John Johnson. You can use any PCB software that can export gerbers, you can import the gerbers into Eagle by converting them using Falk Stricker's Eagle Power Tools.
Welcome to PCBGCODE
Welcome to PCBGCODE
mr2racer,
You are very correct that if you are drilling the same holes in many boards a simple drill fixture and a drill press will do the job. If you are careful and use drill bushings placed carefully in an aluminum plate, add hinges and a simple clamp to hold the boards, you can quickly drill all those holes. I would make it so you could stack a few boards at a time and drill away. The only problem with multiple boards would be the tendency for the drill to wander and drill on an angle with such small diameter drills. Short stub drills would be the preferred choice in my eyes. If you have the money there are some rather small CNC milling machines in the miniature model making magazines I have seen. I was the tooling supervisor in a large aerospace company and this is all relatively easy to accomplish.
diy cnc
Shapeoko | Precision by DefaultShapeoko | Precision by Default
I built a cnc router a while back with a mate of mine and the end result, whilst sturdy and grossly over engineered, was costly and took 2+ years to complete.
This is the cheapest, quickest light duty cnc machine I know of and best of all it's all open source to boot.
So I bought one.
I'm pretty close to getting it up and running - I'll happily report back as to how it does shortly...
So I bought one.
Anyone have any recommendations on a programmable cnc drill? I am getting really tired of manually drilling 40-50+ holes.
How about switch to SMD
How about switch to SMD![]()
SMD is annoying without soldermask.
I have a (crappy) drill press right now, maybe I'll just upgrade to a nice dremel based one that will make it more tolerable.
1. What is the best dremel for pcb hole drilling? Is there a laser guided one?
2. What is the best type of wire drill bits for a dremel?
3. Best dremel holder drill press?
Some thing like this might be a good solution
PCB drilling machine P100/PCB board drill machine/Mini desk drilling machine-in Consumer Electronics Production Lines from Industry & Business on Aliexpress.com
Check this out for a small cnc machine. Very simple if all you want to do is drill holes hundreds or thousands of times.
Sherline CNC Information
And so basically, there are no cheap CNC machines?
My project so far...
CNC photo gallery - The Book Worm
Mac
Hey guys, question about dremel drill bits:
Bosch BL0060 Wire Gauge 1 to 60 Black Oxide Twist Drill Bit Assortment with Metal Index, 60-Piece - Amazon.com
Are these good drill bits and will they work with any dremel, such as this?
3000 Series Rotary Tool Kit-3000-1/25H at The Home Depot
Just want to make sure before I buy all of this.
- Design & Build
- Equipment & Tools
- Cheapest CNC drill?
