i have recently bought a set of 2 bass drivers, and 2 tweeters for us in a car. the tweeters are about 1" accross (inside plastic housing so i cant see), and the bass drivers are approx. 8" with built in metal grill. i do not have any info for these drivers, and they have no name. i bought them from LIDL (spelling?), which is a suppermarket in england, for £10
, which i thought was good, even if they were rubbish.
i wish to use the bass drivers in a subwoofer/subwoofers. how can i find the approx. box size required? the drivers are 4 ohms.
thanks a lot.
thanks a lot.
hi matt, for determining the thielle-small parameters try rod elliott's site www.sound.au.com he has a very good article on that, and then just use winisd to determine the box size and type.
good luck🙂
good luck🙂
do i really need to do all that? do i need to find all the values? cant i just guess how big the box should be?
you need those parameters if you want a good sound out off those speakers, otherwise you will spend a lot of time and effort with nothing to show for it😉
good luck and i hope we hear about how things went🙂 (by the way i'm sorry about the "," at the end of the URL i hope it wasn't much trouble)
cheers
cheers
raindog said:... (by the way i'm sorry about the "," at the end of the URL i hope it wasn't much trouble)
Sorted😉
raindog said:good luck and i hope we hear about how things went🙂 (by the way i'm sorry about the "," at the end of the URL i hope it wasn't much trouble)
cheers
no, i noticed that when the page didnt load and i looked at the address bar. 🙂
- Cheap un-known car drivers
