Cheap SMPS PSUs for class D modules.
It has a 5V output and the +- rails are within the Tripath required range. There is a link in the Ebay listing that provides additional documentation that might help you. I'm new to diy amps (couple 41hz amp3 and SI mod). I'm going to try this with a LM3886 P2P. I did the mod and it gives me 38v. High for the LM3886 but below the max voltage. For my minimal investment I'm willing to plug it in and see what happens. You might want to be more cautious.
Hi bcrescen
The TA0103 can use +/-35 to +/-54V....so these are right in the middle of that range...so I assume that is OK.
My main concern was the amount of power that these SMPS can supply. Most others building amps with TA0103, TA0104 and TA3020 seem to be using large torroidal transformers of around 600VA to 1000VA. The Tripath datasheet mentions something about requiring 7A at +/-45V....but that seems to be at full power - which I don't intend to use.
Anyway - I decided to buy two of those SMPS and will try them in parallel. That should give me +43V @ 4A and -43V @ 4A. Hopefully it will be good enough for typical use at reasonable levels.
BTW - thanks for the link to the SMPS.
finding the eBay SMPS
The link provided points to an expired listing.
Fortunately ebay keeps the records of old listings around for a while after the end of auctions, so I could re-trace that SMPS with a search for items by same seller.
Rather than searching by item nr, which changes all the time, you may be better off searching by keywords in the title, which doesn't seem to change:
"Switching Power Supply Dual +/-43V 2A >Audio power amp",
or by seller id "stadholder"
vectorplane
