What is the maximum board size you can produce ?
I'm after some that are 500mm x 160mm with some very detailed 0.2mm parallel traces. There are a lot of between pad tracks too.
The presented DEMO BOARD , has 40 x 30 mm.........but I can make also smaller.
But any boards ( single layer ) , under 67 cm2 has a flat cost : 2,5 Euro / board.
Can not be many boards on the same panel ( because could be pads and traces errors)
Sorry !!! .......I had in mind that you talk about smaller size .......... now I saw.
So 500 x 160 ....is OK ! for me.
Please send the file of pcb 500x 160 by e-mail.
Is very difficult to tell you the price , because is not depend only of board size.
Far too small for my requirements - sorry.
hi
can you make me some boards using the schematic on this link
http://www.amplimos.it/images/V-fet complementary 2SK82_2SJ28_Ver_B.bmp
regards Sheafer
regards Sheafer
Only if you have the pcb , ready to be made. ( jpeg 600 dpi at least , pdf , ExpressPCB , Eagle , DipTrace ) ..............
If you will go to 320volt.com you'll find very nice projects for MOS-FET amps , complete with pcb's
DXBlame sound very nice
Look there , choose the project with pcb, and send it to my e-mail address.
Regards,
Mihai
Regards,
Mihai
hi
regards Sheafer
Very cheap printed circuit board, can be found in below picture.
Tinned PCB on FR4 support.
Tinned printed circuit boards (PCB) - FR4
Tinned PCB - printed circuit board on FR4 (fiberglass)
I just placed a free PCB layout on mjy website after some requests. The Gerbers are attached. Can people get such PCBs from you, what price?
jan
No answer ?
- Vendor's Bazaar
- Cheap printed circuit boards starting with 0,0375 Euro / cm2
