OK. So I would definately have been better with an aliexpress cheap class D amplifier than this plate amp. But well, now it's bought.
So, I can basically make the box the size I need.
So, a 40x40x60cm box, 96L, would be fine for me ? With the 30cm subwoofer on the front 40x40cm plate, and the plate amp on the other side 40x40cm plate, and a lenght of 60cm between the two. I can go and make this right ? 🙂
Well, it's not 'fine' per se as already noted in our responses, but it has to be since your space limitations, what you bought dictate it and 'we' can only hope that with EQ plus any room/boundary gain it will perform at least adequately for your intended app and as always please let us know how it turned out and what, if any EQ, etc., was required.
GM
GM
