not sure if it's posted anywhere already but just found Weiliang version of Amanero if anybody interested, same pin configuration and similar layout as other OEM clones except it's bit bigger and nearly 50% cheaper
shop link: Italy Amanero usb iis digital interface with program support dsd 512,32b 384K-in Other Consumer Electronics from Consumer Electronics on Aliexpress.com | Alibaba Group
standard OEM: Advanced version Italian Amanero Combo384 USB DSD 512 / PCM 384 module free shipping-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
would it work with this oe would i beed to buy it from the manufacturer?
Amazon.com: LKS Audio MH-DA003 DAC decoder USB DSD Femto Clock black: Electronics
Choose the OEM version - it has better designed PCB.
Plus side, it has pad/hole for bigger size XO like tentlabs.
Anyone try it ? Just curious about erase pin. What happen if we erase the flash, can it be updated /reflash using amanero firmware ?
Topic is a bit old.. Bought from aliexpress cheap amanero clone. After erasing, it cannot be reflashed anymore, following all instruction, in this case reinstall preliminary drivers and converting windows to accept unsigned drivers. Every step was ok, Amanero flashing utility cannot reprogram it, because PID and DID are not recognized
Russians tried to unplug erase jumber just before veryfication and to succeed to program it. For me this is not working, may be amanero are improved to recognoze clones. I even was not aware that facing clone, some checks before would prevent it, but now is later...
Hello , I have the same problemTopic is a bit old.. Bought from aliexpress cheap amanero clone. After erasing, it cannot be reflashed anymore, following all instruction, in this case reinstall preliminary drivers and converting windows to accept unsigned drivers. Every step was ok, Amanero flashing utility cannot reprogram it, because PID and DID are not recognized
Russians tried to unplug erase jumber just before veryfication and to succeed to program it. For me this is not working, may be amanero are improved to recognoze clones. I even was not aware that facing clone, some checks before would prevent it, but now is later...![]()
did you find a solution?
By erasing everything, if that’s the case, you may have lost the bootlogger which is the mechanism for installing new software. That will brick a device.
Someone known a procedure to update or reinstall original firmware on those damn chinese Amanero combo384 ? When I bought it , I dont known was a clone. I cannot use my dac now....
- Digital Source
- cheap Amanero clone
