Compared to the loss you get in the cable, this is miniscule due to the short signal path. Certainly not worth the price difference, unless you are paying for brand name.Neutrik uses a material for their male XLR that has a high dielectric loss (I measured them) in comparison with others. Female ones don't seem to have same problem.
---------------------------------------------------------------------------Prune said:
It is not a loss, but dielectric memory. High quality cable DA is much less unless you use crap stuff. Measure them.
![hot :hot: :hot:](https://files.diyaudio.com/forums/images/smilies/hot.gif)
hello everyone ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
After a long time being lasy I decide to build this DAC and I want to ask a few things.First I want to know about this DAC is autoreset.If s/pdif out of some device is turned of and turned on again do I have to reset DAC manualy???Also I want to know that can I replace LT1962 regulators with LM7805.
If anybody know please help.
Thanx in advance
Thanx in advance
This design is not auto-resetting. Sometimes you must reset the receiver manually after disconnecting the cable.
LM7805 would not fit on this board, but you could alter the design to accomodate them. LM7805 will have worse performance in this role compared to LT1962.
Unfortunately I have no boards for sale. The drawings are available for download in this thread, and they are ready to be sent to board manufacturers.
Good luck!
Good luck!
Shunt
Which question ?
Sorry bu I don't have time to serach your first post.
A. Ciuffoli
www.audiodesignguide.com
Which question ?
A. Ciuffoli
Searching the best DAC testing all
This task will continue on:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=82167
so please send again your post on it.
A. Ciuffoli
A. Ciuffoli
- Digital Source
- Cheap 24/96 DAC, Revision B.
